Why Compression force in Tension members?
In the attached model, i have assigned the Rod Bracing as "Tension Member". But it fails in compression. What is the reason & what is the solution, please clarify.2. JB_053_20_B01_Tyre Curing Press Bldg._R00 (Meghna Innova Rubber Co. Ltd.)(Proposed Bracing).zip
