help me out in resolving this, Whenever i try to link Etabs results into STAAD RCDC, I am getting this error.... presently i am using etabs v18.1.1 and staad rcdc 7.0
Hi
STAAD RCDC 7.0.0 is not compatible with E-tabs 18.1.1. E-tabs has changed format of mdb file. The file which is created by E-tabs is now .accdb file. also the format and content of the data base file has changed in 18.1.1 version.RCDC versions after release of 9.1.0 are compatible to E-tabs 18.1.1. we would suggest you to use RCDC 09.02.00.32 version.
not working..... same problem
Please try to install access runtime driver in your machine as given below. But before installation uninstall the older version of 32 bit in control panel.
after doing this still problem persist
Please mail me your concern at ranjana.shinde@bentley.com or raise a SR to assist you better.
help me out in resolving this, Whenever i try to link Etabs results into STAAD RCDC, I am getting this error.... presently i am using etabs v9.7 and staad rcdc 7.0
https://canhovietreal.com/
Please upgrade your software's to the latest version and check the issue if still persist..
https://softwaredownloads.bentley.com/en/ProductDetails/2303?buildid=20286
click on this link to upgrade RCDC to the latest version .
