SIR I WANT TO KONW WHY MASS IS PROVIDED IS PROVIDED IN GX AND GZ DIRECTION IN MASS REFERENCE LOAD CASE.
It is not necessarily the mass load has to be directed in X or Z only - it can be applied in all three directions. Please refer to STAAD.Pro Help manual chapter TR.31.8.3 Mass Model Using Reference Load.
please tell me how to apply seismic load at y direction as it is showing error
If you are using the equivalent static seismic load generations, you can only apply the loads in the lateral direction X and Z.
