cable analysis
Dear sir,
I am doing cable analysis to find out the reactions to design the base plate. But I am getting reactions only in y-direction. There should be also some reactions in the x-direction. Kindly guide.Staad file is also attached.
The cable is only for an aesthetic look.
.Structure111111.std
Parents Reply
  • Dear sir,
    I have checked with staad pro advance but the reactions are coming with an extreme value like 66kn along x. There is no any weight on the cable only self-weight is considered. Kindly explain to me why reactions are so conservative.
    Also, guide me on what value of initial tension I should consider. The cable will be used o2678.Structure111111.stdnly for an aesthetic look. If there is any need to modify it. Kindly do , It will be really very appreciated.staad File is also attached
    Thank you in advance.
