Hello Team,
How are you?
I would like to know whether do I need to release a moment partially when i use bolted connection in steel beam - beam connection?
If yes, how many percentages of the moment shall be released?
Most engineers do pin the ends of beams with bolted shear connections.
In STAAD do I need to release the beam in MX, MY, and MZ from Specifications to make it pin? and what about KMX, KMY, and KMZ?
You would release MY and MZ. The MX is torsion for a member and so you should avoid releasing that. The KMX, KMY KMZ allows you to define rotational spring stiffness at the start/end of members but I have hardly seen anyone use those.
Hi Sye,
Thank you so much for your kind response.
Can you also suggest me how much % of releases I shall adopt when I connect a C-Section with a similar C-Section and I section Web with an End Plate having 2 High Strength Bolts? The attached picture is for reference.
Thank you
Will this be a Shear / Semi-Rigid?
