Hello there,
I am designing a steel building that has the walls made out of clod formed steel sections. This section is not a simple C-Section with lips, it is little more complicated and is 24" wide and 3.5" deep. Is there a way that I can get STAAD pro to design such a section? I am aware of using the "User Defined Table" But since my shape is not part of a standard section database , I realized that this will not work. Please let me know if you have a work around. Common industry practice is to use a software like CFS (Cold Formed Steel) to design the these sections, but if possible I want to get everything done within STAAD Pro.
Cold formed section design is limited to standard sections in STAAD.Pro. If the shape is non standard, STAAD will not design it.
Thank you! I was hoping there will be some kind of workaround. Thanks for your response though.
