the below code uses GetSectionPropertyValuesEx which is not working .
refering to the previous thread
https://communities.bentley.com/products/ram-staad/f/ram-staad-forum/119259/member-properties-for-web-tapered-sections-in-open-staad
"prop" array is still not getting populated
the description of this function in excel object browser is
Function GetSectionPropertyValuesEx(varProfRefNo, varPropType, varPropValues)
second argument " varPropType" for that used GetBeamSectionPropertyTypeNo
the updated openstaad manual also doesnt cover this .
could someone please highlight where i am wrong ?
Sub webTap_secprop()
Set OS = GetObject(, "StaadPro.OpenSTAAD") Set OSGeometry = OS.Geometry Set OSProperty = OS.Property '**************************** Dim SelBeamsNo As Long Dim SelBeams() As Long 'Get the application object -- 'Get no. of selected beams SelBeamsNo = OSGeometry.GetNoOfSelectedBeams 'Reallocate ReDim SelBeams(SelBeamsNo - 1) As Long OSGeometry.GetSelectedBeams SelBeams, 0 For i = 0 To (SelBeamsNo - 1) 'get section properties of tapred section Dim Fone As Double, prop(0 To 6) As Double Dim lBSPropertyTypeNo As Long Dim lBSPropertyrefNo As Integer lBSPropertyrefNo = OSProperty.GetBeamSectionPropertyRefNo(SelBeams(i)) lBSPropertyTypeNo = OSProperty.GetBeamSectionPropertyTypeNo(SelBeams(i)) OSProperty.GetSectionPropertyValuesEx lBSPropertyrefNo, lBSPropertyTypeNo, prop Next i End Sub
Can you please try with this function?
GetBeamProperty (nBeamNo, varfWidth, varfDepth, varfAx, varfAy, varfAz, varfIx, varfIy, varfIz)
this function works well for tapers members , but we cannot get crossection size( flange width and thcikness from it ) .
Best Regards,
Alex Immanuel Thainese
Please try with this function
GetBeamPropertyAll (nBeamNo, varfWidth, varfDepth, varfAx, varfAy, varfAz, varfIx, varfIy, varfIz, varfTf, varfTw)
this function too will not provide the required
it will not give flange width and thickness at top and bottom location , it can be used for double symmetric sections
dear shreyankar ,
did you tried finding out about GetSectionPropertyValuesEx.
is it a bug which needs to be corrected ?
i even tried it in connect edition in inbuilt macro editor , the code is running but it is not populating the values of Tapered I ,
the values of F1 to F7 as shown in figure below
below is the code from staad connect edition macro editor
Option Explicit Sub Main() 'DESCRIPTION:Creates a new view from the selected beams. Dim objOpenSTAAD As Object Dim SelBeamsNo As Long Dim SelBeams() As Long 'Launch OpenSTAAD Object Set objOpenSTAAD = GetObject(,"StaadPro.OpenSTAAD") 'Get no. of selected beams SelBeamsNo = objOpenSTAAD.Geometry.GetNoOfSelectedBeams If (SelBeamsNo > 0) Then ReDim SelBeams(SelBeamsNo) As Long objOpenSTAAD.Geometry.GetSelectedBeams SelBeams, 1 Debug.Print SelBeams(0) Dim RetVal As Variant RetVal= objOpenSTAAD.Property.GetBeamSectionPropertyTypeNo(SelBeams(0)) Debug.Print "Value of RetVal- " & RetVal Dim lBSPropertyTypeNo As Long lBSPropertyTypeNo = objOpenSTAAD.Property. GetBeamSectionPropertyRefNo (SelBeams(0)) Debug.Print "Value of BeamSectionPropertyRefNo- " & lBSPropertyTypeNo Dim lBeamSectionName As String lBeamSectionName = objOpenSTAAD.Property.GetBeamSectionName (SelBeams(0)) Debug.Print "Name of BeamSection- " & lBeamSectionName Dim PropArray(0 To 6) As Double objOpenSTAAD.Property.GetSectionPropertyValuesEx lBSPropertyTypeNo,PropArray( ) Dim i As Integer For i = LBound(PropArray) To UBound(PropArray) Debug.Print PropArray(i) Next i End If Set objOpenSTAAD = Nothing End Sub
