All,
I have a question regarding the file compatibility of STAAD Foundation.
I worked on foundation design using STAAD Foundation 8.3.
Are files created using STAAD Foundation 8.3 compatible with STAAD Foundation 9.xx versions?
Yes these should be compatible. If you have a mat model meshed in ver 8.3 when you open it in SFA version 9.3.0.14, it will regenerate the mesh as the meshing algorithm has been vastly improved in the latest version. You would not lose any data but just the mesh would be regenerated.
