<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>ADD MORE PARAMETER TO DEFINE THE TAPER SECTION</title><link>https://communities.bentley.com/products/ram-staad/f/ram-staad-forum/200779/add-more-parameter-to-define-the-taper-section</link><description>If the width of the flange at stat node can de different with the width of the flange at end node ?
 Current only width of top and bottom flange can de defined seperately.</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: ADD MORE PARAMETER TO DEFINE THE TAPER SECTION</title><link>https://communities.bentley.com/thread/599933?ContentTypeID=1</link><pubDate>Thu, 23 Jul 2020 16:09:22 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:7c800b19-b8ad-4bf4-8259-14dc6c46e112</guid><dc:creator>Sye</dc:creator><description>&lt;p&gt;As of now there is no way to do that. You may split the beam into segments and specify a different flange width for each segment. Each segment would have a constant flange width but at least you would be able to&amp;nbsp;capture the variation of flange widths across the segments.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
