RCDC (SACD) showing error while redesigning columns and shear wall.
rcdc showing error when redesigning shear wall from already designed column in redesign column or redesign section menu.
ERROR:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at ColumnDesignTool.ScColumnWalldMan.GetMaxASVForWalls(Collection ShearDataColl, DataRow[] LoadCombForcesDR, Collection oColBeamData, Boolean bConsiderBeamShear)
at ColumnDesignTool.ScColumnWalldMan.DesignAllSectionR(Collection OptionDataColl, String s_Operation)
at ColumnDesignTool.ScColumnWalldMan.RedesignSection(Collection wColDataColl, String s_Operation)
at ColumnDesignTool.ColDesignParameters.RedesignEntireCol(Collection wColColl)
at ColumnDesignTool.frmRedesignEntireCol.StartRedesignEntireCol()
at ColumnDesignTool.frmRedesignEntireCol.OK_Button_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4200.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
RCDC
Assembly Version: 1.0.0.0
Win32 Version: 09.03.00.25
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/RCDC.exe
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 14.8.3752.0 built by: NET48REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.8.3752.0 built by: NET48REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
SandDock
Assembly Version: 3.0.6.1
Win32 Version: 3.0.6.1
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/SandDock.DLL
SCMap
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/SCMap.DLL
RCDCIO
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/RCDCIO.DLL
System.Web
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
System.Data
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
Automation
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/Automation.DLL
SCDBDesign
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/SCDBDesign.DLL
hasp_net_windows
Assembly Version: 7.5.1.61541
Win32 Version: 7.5.1.61541
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/hasp_net_windows.DLL
Bentley.Connect.Client.API
Win32 Version: 10.00.19.27
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/Bentley.Connect.Client.API.DLL
Bentley.Connect.Client.Service.Interface
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/Bentley.Connect.Client.Service.Interface.DLL
System.ServiceModel
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll
System.Runtime.Serialization
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
SMDiagnostics
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/SMDiagnostics/v4.0_4.0.0.0__b77a5c561934e089/SMDiagnostics.dll
System.ServiceModel.Internals
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Internals/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Internals.dll
Bentley.Connect.Advisor.Api
Win32 Version: 10.01.00.270
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/Bentley.Connect.Advisor.Api.DLL
Bentley.Connect.Advisor.ApiFactory
CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/Bentley.Connect.Advisor.ApiFactory.dll
Bentley.Connect.Advisor.Logging
CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/Bentley.Connect.Advisor.Logging.DLL
log4net
Assembly Version: 1.2.15.0
Win32 Version: 1.2.15.0
CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/log4net.DLL
Bentley.Connect.Advisor.OopWrapper
CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/Bentley.Connect.Advisor.OopWrapper.dll
Bentley.Connect.Advisor.Api2
CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/Bentley.Connect.Advisor.Api2.DLL
Bentley.Connect.Advisor.ServiceContract
CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/Bentley.Connect.Advisor.ServiceContract.DLL
ScIO
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/ScIO.DLL
System.Data.SQLite
Assembly Version: 1.0.110.0
Win32 Version: 1.0.110.0
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/System.Data.SQLite.DLL
System.Transactions
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
System.EnterpriseServices
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
StyleManager
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/StyleManager.DLL
System.Numerics
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
SCModel
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/SCModel.DLL
ColumnDesignTool
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/ColumnDesignTool.EXE
FootingDesignTool
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/FootingDesignTool.EXE
PileCapDesignTool
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/PileCapDesignTool.EXE
SlabDesignTool
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/SlabDesignTool.EXE
BeamDesignTool
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/BeamDesignTool.EXE
bentley.managed.entliclib
Win32 Version: 11.00.08.10
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/bentley.managed.entliclib.DLL
Bentley.Licensing.Client.API
Win32 Version: 11.00.09.07
CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECTION%20Client/LicService/Bentley.Licensing.Client.API.dll
Bentley.Licensing.ServiceInterface
CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECTION%20Client/LicService/Bentley.Licensing.ServiceInterface.DLL
WW
Assembly Version: 2.0.6.4
Win32 Version: 2.0.6.4
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/WW.DLL
BBSElements
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/BBSElements.DLL
WW.Cad
Assembly Version: 2.0.23.10
Win32 Version: 2.0.23.10
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/WW.Cad.DLL
System.Security
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Security/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Security.dll
WW.License
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/WW.License.DLL
SCMath
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/SCMath.DLL
ScdMan
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/ScdMan.DLL
SCDwg
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/SCDwg.DLL
DXFViewer
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/DXFViewer.DLL
LoadComb
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/LoadComb.DLL
ObjectStructures
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/ObjectStructures.DLL
SCControls
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/SCControls.DLL
scisde
CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/scisde.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
