Hello
How do i assign the section properties to design the steel structure? WIth what section should I start?
It will be very much helpful if someone can give me the staad code of a real steel building.
Please refer to STAAD.Pro Help manual Tutorials chapter - there are step-by-step examples.
Have you done the steel strucutres?
Yes both Steel and Concrete tutorials are there.
Hello Sye
Thank you for your reply. Can you send a steel building for the reference? It will be very much helpful. Thanks.
The STAAD.Pro models associated with these tutorials are available as part of the installation. From the start page if you click on Sample Models > Tutorials you will be able to find these.
In addition there are trainings available on the Bentley Learn Server for example here is one on the design of steel structures and you can download the associated datasets for these trainings as well
https://learn.bentley.com/app/Public/ViewLearningPathDetails?lpId=111708
Answer Verified By: Gokul Saud
