I have ram concrete running issues.
I got a message that "tolerance error. Check that all members at this coordinate are aligned "
even though I aligned all walls, I have the same issue.
Is the problem because of the slop roof with semi diaphragm?
please let me know.
It could be. Setting the level flat in a copy of the model is a good test. For more see: https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/4027/ram-meshing-and-segmentation-tn
