Portal Brace / Wind Bent in PEB building
Hi All,
I have a requirement to avoid cross bracing and introduce Portal Brace / Wind Bent (Red Colour) in PEB building. The Red columns flanges are stitch bolted/welded to the webs of the rigid frame columns (tapered) and extend down to 150 mm above F.F.L. Please advise the best way to model this in Staad and any other points to consider. A sample model for reference would be highly appreciated.
