Trying to model a 3 dimensional Plate. Using a basic mesh. Whenever I use the parametric models feature to create a mesh, the program freezes then crashes. Attached I have a photo of the mesh I am trying to create and the error I receive. The gusset plate is a standard mesh and works fine, but the automatic mesh feature for basic and standard does not work for the bottom plate. Let me know what I can do.
Here is another photo of the program mid crash after trying to make a basic mesh in the selected area shown on the left. Crashes whether I use a large mesh size or a small mesh size.
Can you please upload the model. Also are you using the latest STAAD.Pro 22.04.00.40 ?
Hi Sye, I am using version 22.03.00.28. However, I had the same issue using version 4 on another device.
There are some duplicate nodes in your model which cause this issue. Go to Utilities -> Node Tools -> Duplicate Nodes and Remove All Duplicates. Now you should be able to generate mesh on both plates.
Running into the same issue even when removing the single duplicate node.
