Good evening,
I need to perform static seismic analysis according to Eurocode Standard (evaluation of equivalent lateral forces of a structure at each level/floor). Is it possible with STAAD_Pro ? Is there a procedure to follow or some examples availabe?
Thank you,
SConti
Equivalent static seismic load generation as per EC8 is currently not available in STAAD.Pro. One can do a response spectrum load generation as per the EC8, in case that helps.
Hi Sye
Can you please let me know where I can find a step by step example for EC8, I could find this one below but no step by step
You can refer to that attached example-
Eurocode8_RC designer.std
How the ZPA acceleration value is set on frequency units, 33 HZ. The acceleration should be on unitary values of g. What value of g correspond to 33Hz
Please refer to the attached section of Technical Reference manual. The parameter value used in ZPA corresponds to Hz.
PDF
