Dear Sir,
I am having trouble designing some of the connections.I have also grouped the unassigned / undersigned members as BCF, BCW & BG for the first floor only. Please show me how to avoid it and design these members.
40.rar
Please attach the related STAAD.Pro model and let us know the exact version of STAAD.Pro which you are using.
Sir I am using Stadd.pro version 22.04.00.40.
3051.rar
The results for both connection at node 1781 are the same, isn't it?
No Sir, what you suggest?
Please attach this model.
7485.rar
pl. find the attached file
Please see the screenshot below. As you can see, at node 1781, member 5445 is considered as a Girder in your model. This is not correct, I believe, as member 5445 should be considered as a Beam and members 70 and 4921 should be considered as a Girder. So if you swap beam and girder at these connections using this tool, the utilization ratio of both connections becomes the same, so one of those can be deleted.
Thank you Sir.
