Dear Sir,
I am having trouble designing some of the connections.I have also grouped the unassigned / undersigned members as BCF, BCW & BG for the first floor only. Please show me how to avoid it and design these members.
40.rar
Sir I am attaching an image for better idea, as their are many nodes. this is an image of first floor level.
Please let us know at least one node where Beam to Girder connection cannot be created.
Sir node number 4,29,42,60,5,30,43,61 & 98, are some of the nodes that are fully or partially unassigned with BG template.
Nodes 4, 60 and 98 are a beam to column connection, not a beam girder connection. I see that the remaining nodes which you mentioned do have a beam girder connections assigned and designed.
If you look at node 1781 , which is connected between beam nos 70,4921,5445, two BG connections, while node 1776 is also connected with three members is not provided with similar connections.
