I am not able to use the RAM DataAccess Library in the excel. It says the the library is missing inside the macro.
RAM SS v17.01 did not install the 32bit version of RAM DataAccess; it only installed the 64bit version. If your applications were using the 32bit version from previous versions of RAM SS, your applications would stop working, as you described. RAM SS v17.02 now installs both the 32bit and the 64bit versions of RAM DataAccess, so the problem should now be resolved, if you update to RAM SS v17.02 (it won't be necessary to perform the steps outlined above for restoring the 32bit version!). Please note that we no longer support a 32bit version of RAM SS; it is likely that at some point in the future we will have to stop supporting the 32bit version of RAM DataAccess, so I recommend that you transition to the 64bit version.
