I am not able to use the RAM DataAccess Library in the excel. It says the the library is missing inside the macro.
Yes it's the command prompt.
Then enter: cd C:\Program Files (x86)\xxxxxxx\xxxxxxx\xxxxxx navigating to directory where you unpacked the zip archive.
Then enter regsvr32 ramdataaccess.dll note that there is a typo in Seth's answer. This should register the new library and then you are good to go.
Here is what I'm getting trying to register the DLL
Am I missing some dependencies?
Make sure you navigate to the folder with the files first, or add the full path to the regsvr32 command.
Or this one:
What Windows are you running? The files and discussion above are for Windows 10 (x64) with MS Office x32.
