Staad Pro SS6 - Toolbars locations reset
Hello
Please see attached image. Staad Pro toolbars locations have been reset in my system and I am unable to fix this issue. Requesting guidance to resolve this problem.
Thank you.
Parents Reply Children
  • That is odd. Well in that case, you may ask the system admin to uninstall STAAD.Pro v8i, search the registry by the term STAAD and remove all such keys/strings manually. Anything left over in the installation folder ( default C:\SProV8i SS6 ) can also be deleted manually.
    The better solution would be to just install the STAAD.Pro CONNECT Edition. Yes it can co-exist with STAAD.Pro v8i but the support for STAAD.Pro v8i is going to discontinued at the end of this year. So the best solution at this point would be to migrate to STAAD.Pro CONNECT Edition.
