Hello
In Ram Structural, I have the same arrangement of the vertical braces in several elevations, how can I copy in the other elevations?, also the fixity assignment in beams and columns. Thanks.
Robinson
Regretfully there is no copy function from elevation to elevation in RAM SS yet. Modeling the braces manually is probably the best bet. The other route is through ISM import, but that can be tricky.
Thank you for the answer Seth
Robinson,
One of our colleagues recently created a RAM DataAccess tool that can be used to quickly model braces in a RAM Structural System model. Using this tool will likely reduce some of the modeling effort for the vertical braces you mention.
You can register for an on-demand webinar that demonstrates how to use the tool here.
You can download the Excel file for the tool here.
Thanks, Karl, it will be very helpful.
