I have designed my steel frame with wall bearing system with some internal steel columns, with beams and girders supporting a composite roof slab. I built the model in RAM structural System and after making sure i got the beams and columns designed, i proceed with selecting the RAM connection toggle that was provide and it brought me to Ram Connection. However the first error message pops out and says "[Title] Load conditions:[Warning] The analyzed load cases have changed and load combinations should be regenerated.[Warning] None load combinations could be read from the model."
then the model proceed to open and when i try to assign a connection to the nodes this happens for all the nodes. any idea why or how to tackle this?
Best,
Kenneth
To assign a connection you typically need to select two or more intersecting members and the node. For more see:
https://communities.bentley.com/products/structural/structural_analysis___design/w/structural_analysis_and_design__wiki/troubleshooting-errors-when-assigning-connections.aspx
and: https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/8105/ram-connection-capabilities-and-modeling-faq
regarding combinations see: https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/42274/ram-connection-seismic-provisions-settings
