*** ERROR *** ABOVE LINE CONTAINS ERRONEOUS DATA.
I am new to STAAD and I don't particularly understand the required syntax. Maybe I do not have the order of operations correct or maybe something is missing.
I am trying to run a lifting analysis on a skid for a pressure vessel. I am in a time crunch and need to get this working ASAP. I have started working in steps on my way to a good final analysis. At this point I want to simply solve the analysis and check results for CoG. I am currently getting an ERROR that appears to be with a load, though I do not understand it since my loads have all been defined and attached to members.
If someone could help me out that would be greatly appreciated!
 GDP Horizontal Slug Catcher ZZZ-101.STD
