I have modeled the weird shape mat slab that we have in one of our projects. But the reinforcement I am getting is so huge. I mean I have already inputted user reinforcement #6@9"O.C T&B and in addition to that I am getting huge reinforcement. Can you please help me with this? Not sure if this has to do with design strips.
I also wanted to ask about meshing. How much small element can I have? In the above model I have 3'. Does this element size dependent on something?
I have attached the model in drop box link so that you can have a look at it. It didn't let me upload it here since the size was 9MB. Any suggestions for such a complicated slab would be much appreciated.
Dropbox link - www.dropbox.com/.../AAD-7w6-IvmXX6mqcRwCGJNoa
Ankith Patel
There are some very large cantilevers, like the one marked in the image below. Are you counting on soil support in this area? If so, modeling an area spring would help reduce moments. Otherwise, you will need something much thicker than a 9" slab.
Section 19.1.1 in the RAM Concept Manual (excerpt below) has some general guidance on mesh size.
Regarding design strips, I recommend using the "Orient Span Cross Section" tool so that the cross sections within the design strips are perpendicular to the user reinforcement that is modeled. Chapter 23 "Defining Design Strips" in the RAM Concept Manual has more information on using that tool
Karl,
Almost whole perimeter of the slab is supported by beams(Grade beams). There shouldn't be any cantilevers. In regards to design strips I did use tool "Orient span cross section" to have perpendicular reinforcement. I have done all that and even after that I got huge reinforcement. Please look at model and let me know if there are any other issues. At some locations I have so huge reinf like 55-#5 in just 10'-0" width.
Ankith Patel.
Ankith,
Yes, but there is nothing supporing the perimeter beams except other perimeter beams, which means that the slab is essentially a large cantilever. This is leading to extremely large moments, which leads to the excessive reinforcement. If these are grade beams, then you should model area springs to account for the soil support.
Not all span segments have the cross section oriented so that the user reinforcement is perpendicular to the sections. One example is shown in the image below.
Okay let me correct that. And in my case I will use "line spring" tool to assign spring properties to these Grade beams right? Also do I need to assign any soil properties?
I would use an area spring that is modeled over the beam width. The advantage of using area springs versus a line spring is that the zero-tension analysis applies to area springs but not to line springs, which are always tension/compression.
