How does STAAD determine beam deflections?
I am modeling a floor slab (1 ft thick) with concrete beams (all 24" wide x 36" deep). These beams will be cast monolithically with the floor slab, therefore the beams are modeled as 24" deep.
My question is how does STAAD determine the following beam deflections? What are the formulas? What criteria is taken?
(The particular beam in question is highlighted in blue. The red beam selected is the one segment determined with the max deflection. The circled deflections on the right of the image is what I'm questioning how STAAD obtained these values.)
Any help will be greatly appreciated. Basically, I want to check these values, perhaps by hand, and conform my STAAD output is reasonable.
Best,
Pascual
Parents Reply
  • By saying "displacement at the node at the start of the member", do you mean for this case the deflection is at node 1660?
    If so, yes I understand that. What I don't understand is how STAAD is getting that deflection.
    There are several beam segments along the line in red. I modeled beams between nodes with the plate mesh along the red line I show.
    The literature on the stiffness analysis you shared didn't help on understanding how STAAD is getting the deflection of -0.230 in. Trying to do hand calcs to compare, I am not getting anything close.
