Slab Edge Coordinates - Data Extraction
I am trying to rebuild my RAM edge of slab outside of the program using node coordinates. I am currently using the "Data Echo" data export in RAM Structural System, but as can be seen in my screen shot, the "Data Echo" does not specify whether the Edge Distance is to the left or to the right and thus I cannot accurately capture this information. I do not want to set my edge distance to 0 in order to avoid this problem. In what data tables (Post-Processing > Extract Data, etc.) can I find sufficient information to rebuild my edge of slab using coordinates or line segments?
Thank you.
