Beam Deflection Problem
I really need your help.
This is the problem.
I have a trimmed model of the Hoist structure, the beams along columns as highlighted in Red in Fig1.pdf failed in deflection as the result in Analysis.
There are large deflection values at main cantilever members.
The following are already tested in the model but will still fail in design.
  1. Increase of beam size
  2. Addition of knee brace
  3. Deleted loads on the beam.
Q1.Is there something wrong with the parameters set for a cantilever beam?
Q2. The members are assigned with MAster slave to columns to consider the actual length, is this method correct?
Q3. Does the failure have to do with Built-up column section?
Does the main column have anything to do with the effects of the cantilever beam?
Notes : This model was run in STAAD.Pro v8i SS6 Build 20.07.11.90. When I try to run the analysis in STAAD Advanced Connect Edition, I encounter error in analysis.
Thank you very much in advance.
Have a great day!
Attachments below
PDFAbsorber_Maintenance_Str_09042020_Drift_offsetCAN_orig2.std
