Hi all,
I'd like to generate a Beam End Forces report table.
However, due to a large number of beams and loadcases, the table could take up to 50-60 pages per property type that I selected.
Is there a way to just generate a report table for envelope of selected load cases?
I am new to STAAD Pro, please bear with me for a lot more basic questions to come.
Thank you.
Click on the Select Load Case icon in the Results menu and select the load cases which you are interested in. Then go to the Beam Results and click on the Envelopes tab in the Beam End Forces table.
Hi Modestas, Thank you for replying.However this normal Envelope feature is tabulating the whole beams. I am looking for a more compact envelope forces presentation of selected beams only.
You may follow this Wiki then: https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/37082/finding-out-the-max-forces-displacements-support-reactions-stresses-for-a-group-of-entities
