RAM Frame - No compression on column
I have two shared BRBF columns that are not calculating expected capacity forces of the braces. I've tried a number of items to make it work, but I haven't had any luck. It is saying "no compression on column" and "no tension on column." The most confusing part is I have similar frames in the other direction that look to be calculating properly. I was having difficulty getting those to calculate as well, but it was at least running a check.
Any thoughts? These are multi-tiered frames to support a bridge, with SMF above.
 Roy Building 3 - Pedestrian Bridge - MTBF.rss
Parents Reply Children
