I'm attempting to print the calculation report for a concrete mat foundation slab in Ram Concept. The report has been printing for over 4 hours now. There are about 400 sheets in the report. It started off fast-- the progress bar showed it getting through the first 20 or 30 sheets in a matter of seconds, but after that the progress slowed down. It has been 4 hours and the progress is only at 83%. Is this normal? Is there any way to speed it up? Before printing I went through the "Include" in report list and set most things to "No". I'm attempting to print the report to PDF. Would that make any difference?
Thanks.
I suspect that the report is locking up on a particular page/layer. We probably need your file for testing as it might relate to the size of the plan, print scale, or other print settings. In the meantime, you can try excluding even more layers, or printing select layers one at a time. Also let us know your version number and if you are using the direct pdf print option in Concept or a regular print with a pdf print driver.
