When I run the RAM FRAME I get this error. Why would this occur on one level and not every load case? I have checked the total applied load in the loads and applied forces report versus the total base shear. Its only a couple kips.
In a semi-rigid diaphragm the wind load gets applied to the nodes along the edges. You can see this using process - results - applied story forces. There may be an acute angle to the edge or missing deck assignment causing the issue. See: https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/2052/ram-frame---wind-loads-faq
Answer Verified By: Timothy Schuster
