In the Ram Concrete module, When I run the Process > Analyze, it gives me the attached warning message:
I assume the warning is referring to the highlighted line that says "Either all Degrees of Freedom Fixed or Internal Error." Does anyone know what this is referring to or how to resolve it? Thanks,
Is there a level (5?) that has nothing on it? Regardless, the analysis is running and you should be able to check results like deflected shape or reactions to confirm it's working as intended.
