Been trying to export out a design of a Cell beam in RAM into Westok's propriety program but much to my frustration the file extensions are different.
RAM exports the file as a .cbx, yet Westok looks for a .cbxx file. Now even if I change the extension the file will not open.
Anyone have a solution to this?
Cheers
As you note, the current link does not work as Westok changed the file extension. We are looking to reinstate this link and hope we can achieve this in the near future.
Answer Verified By: Craig Orrell
Hi Craig,
if you need further assistance on this scheme, please get in touch: john.callanan@kloeckner.com
John Callanan
KMUK Westok Design Team Manager
Hi John,
I managed to get most of the designs out using the inbuilt RAM Westok cellbeam designer and had to check a beam in Westok's program and had to input the values in manually. It was just a faff having to do that but managed it, it just a scheme design atm.
