I have a 400mm flat plate that I would like to "bend" 100mm from the bottom at an angle of 60 degrees. The highlighted portion of the plate is what I would like to bend.
I am also using trapezoidal loading and am wondering how this might be affected following the bending.
Hi Matt C 17,
The Generate-Rotate tool should help:
The applied loads may need revision - if they are applied in global axis direction - they will no longer be applied as expected.
Answer Verified By: Matt C 17
Thanks for your advice.
