Is there a way to do a statics check in RAM concept? I'd like to know the total vertical load for a load case. Alternatively, is there a way to export point spring reactions to a Table that I could sum in Excel?
The total forces and reactions (equilibrium check) are in the calc log. There are spring reaction tables for loads, load combos etc. and any of these can be exported to Excel. Note, our next version also has a scripting API you might be interested in. https://communities.bentley.com/products/ram-staad/f/ram-staad-forum/199231/does-ram-concept-support-apis
Answer Verified By: Gumpmaster
Thanks Seth, that's exactly what I needed.
For others reading this, the calc log is under the Report tab. The reaction tables are under each individual load combination.
