Hi,May I know if there is a workaround to get a displacement summary report for each property type?I understand that for forces we could do this by using 'Max Forces by Property' feature, however I don't see the same option for displacement.
Thanks.
You can get the beam displacement summary report for fifferent member properties.
Go to Postprocessing > report > report setup and take beam diplacement summary from output as shown below.
Then go to range, select property and then take required property from the dropdown and hit ok.
Hope this helps.
Thanks!!
