Connection assignment in Staad
I have a steel warehouse design with tapper sections. The combination were defined by myself using edit rules in load generation.
 After the unity check and redesigning sections, I went to Connection Design. Here when I select the knee connection for the column rafter joint (column and rafter both are tapper section), an message appear saying tapper section is not tappered. And the connection is not assigned.
How I solve the issue.
