Staad Pro Connect edition WT description problem
Why is it that everytime I open a working staad model, my WT sections are always back to W and when I generate a dxf file, the WTs are Ws.
  • I am not able to replicate the issue. What is the version number of STAAD.Pro? If it is not the latest one (22.05.00.131), please upgrade to that one.
    Please make sure that the T sections are specified in the input command file as shown next
    1 TO 25 TABLE T W21X275
    200 201 202 TABLE T W18X40
  • this is how it looks like, it starts by just saying it is a Tee, but the model shows a W8x18 not a WT4x9. Staad version 22.04.00.40
  • The section is still a Tee section that is cut from a Wide Flange ( W8X18). The fact that the Properties - Whole Structure window shows the section as W8X18 Tee, confirms that it is a T section. Also the editor command shows member 121 to 124 as T section cut from W8X18. If it was a W section, the command would have been 121 TO 124 TABLE ST W8X18. Another way to verify that the section is a T section is by double clicking on the member and checking the section name as shown next
    The fact that the software is graphically displaying the property as W8X18 as opposed to WT4X9 is definitely a display error and I will notify our development desk about it, but rest assured that the section is still a Tee section.
  • Also for the records Defect 975241is logged in our bug tracking system for this problem and this will be addressed in the software
  • Sye,
    You have been very helpful and I would like to see if you can keep helping me, I just posted a new question, I am having problems with my horizontal bracings, and I am downgrading to previous version since the new one is giving very odd results:
    Version 22.04.00.40 had this results:
    Mario Cuervo
    Senior Civil Structural Engineer
    E: Mario.Cuervo@cloughgroup.com
    D: 281-842-5602
    This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom it is addressed. If you have received this email in error please notify the sender and delete the email. Any material that may constitute legal advice or opinion is solely for the reliance and use of Clough Limited and its related bodies corporate. You should only read, disclose, re-transmit, copy, distribute, act in reliance on or commercialise the information if you are authorised to do so. Please consider the environment before printing this email.
    Vesion 22.05.00.131 have this results:
    Same member, same size, same everything but the results are way too different.
