Hello Everyone
Which is better to intersect the primary beam and secondary beam (Figure1), or Merge the primary beam to be one (Figure2)?
Hi Ibrahim,
if you are using the analytical modeler of STAADPro, you'll need a node at the intersection of the girder and the beam. if you merge the two parts of the girder, your beam will not be supported (connected) by the girder.
B. ZIANE
Thank you so much can you share with me a Reference or evidence.
You may refer to the following wiki for reference.
https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/20702/connectivity-issues
Answer Verified By: Sulaiman Ade
