Error in member ratios -nan(ind)
Hi. I am working on a steel building, and i have a couple of issues.
There is a column that shows a ratio of 13. And when i calculate it by my own taking from the model the nodal displacements for that combination, it should be aprox 0.54.
There are two other members that show "-nan(ind)". I have never seen that... no idea what the problem could be.
I tried running the model in version V8i, and i do not receive that error, and the ratio of the column is exactly what i calculated.
There is another member that shows a ratio of 1.34e+17.
Anyone can help?
Thanks!
Parents Reply Children
