Extended Shear Tab Buckling Limit State
I am reviewing (column beam brace) vertical brace connections that use unstiffened single plate connections for the gusset to column web interface. The fabricator has extended the plates out past the column flanges for constructability.
After reviewing the design checks in RAM, I do not see any checks for plate buckling per AISC 360-10 Part 9. For the extended configuration, page 10-105 requires design check 5 which is
"5.Check the plate for the limit state of buckling using the double-coped beam procedure given in Part 9".  Can you verify whether or not this check is being performed?
Thank you for your attention to this matter,
Quinton
