Ram Concrete Column Buckling
How is RAM using the nomograph to calculate the K factor for a non-sway column that is braced by the slab? Under the "bracing criteria" if I keep the assignment as "slab braces the column" but I don't have a beam framing directly into the column in that axis, how is (EI/L) calculated for the "beam"? Is a section of the slab used for that calculation?
I have an instance with a girder framing into the column in the N-S direction, but there's not a girder on the column line in the E-W direction, but both of my k values for the major and minor axis are 0.9. I would've thought I would have 0.9 for the N-S direction, and a factor of 1.0 where I'm "pinned" by the slab. Any advice is much appreciated! Thanks.
