RAM Concrete Gravity Column Base Moments
Is there a way to look at the column moments for a gravity column in a diagram presented similarly to RAM Frame? I have a gravity column that is assigned as pinned at the base, but my major axis moment doesn't return to 0? Only the minor axis moment returns to 0. Do you know why that may be happening?
