The staad model was done in staad V8i version from other user.
When I tried to open the model in connect edition, assigned japanese steel section was missing and I need to reassign those member before analysis.
May I know how to solve this problem?
Please attach that model if possible.
Attached for your reference.
15.11.19 (combined).std
In STAAD.Pro CE go to Specification -> Section Database -> Configuration and change the Japanese section database to 'japanesesectionslegacy'. Then restart STAAD.Pro and see if you can open this model fine.
Answer Verified By: preka maju
yes, it helps. thanks
