Kindly help with the below issue:
The below screenshots showing different analysis results for the same member in the same model utilizing STAAD pro connect V22 update 4 and update 5 versions,
Noting that the STAAD model analysis results shows that the given member (Which has "member truss" specification) carries about 2 tons of axial force in case of Update 4 version and older while it gives like 10 tons in case of using update 5 version !
Your quick response is highly appreciated
Thanks in advance
Note: the given example is not the only conflict case. (This issue included different structural members like: beams, HZ bracing members & VL bracing members).
Staad.pro Update 4 and older
The new Staad.pro Update 5
BUG 510695 was causing axial forces to be incorrectly computed in truss members in Update 5 (build 22.05.00.131). The bug has been addressed and now for truss members results should match/be close to what they were in Update 4. Would request to check results in Update 6 (build 22.06.00.138) or later and see if results match with Update 4.
Answer Verified By: Ahmed Medhat
Thanks a lot Eng.Suvadeep.
