RCC STRUCTURAL DESIGN AS PER IS 13920-2016
While deigning structure in staad as per IS 13920 i got following Note in output.
NOTE :- SOME OF THE BEAMS CONNECTED TO THE COLUMN NO. ** ARE NOT DESIGNED. ONLY SHEAR FORCE FROM ANALYSIS WILL BE CONSIDERED FOR SHEAR DESIGN.
Please suggest me any solution to remove this note. Also please tell me whether this is any kind of error. Or my file is not executed successfully.?
