Opening Older RAM Files
Hi All,
The company I work for has been using RAM Structural System for a few decades now. One of the reasons we've decided to keep using RAM for all these years is because we are often acquired to renovate or make additions to an existing structure that we have worked on in the past. Staying with one structural analysis software allows us to use already developed models from when we last worked on the structure.
Recently we have been asked to renovate a structure that we had designed back in 2005. We have a RAM model already from when we first worked on the structure, however, we seem to be having difficulty opening the model. When I try to open the file I first get the pop up box,
I select yes, and then get the warning,
I select OK, and then I am brought to RAM Manager. I can see in file explorer that the file type has been converted from "filename.ram" to "filename.rss." Then, when I click on RAM Modeler, I get the error,
I click OK, and get another warning, similar to above,
I then click OK, and go to Criteria > Master Steel Table > ramaisc > OK. The software then crashes. This seems to happening for all our RAM models from 2005 and before. Has anyone experienced this issue before and is there a fix to this issue?  It's necessary to us to use the old models, as it would take days to remodel the existing structure. Thank you.
Frame3revJuly6.ramSteel Framing.ramFloor Addition.ram
