Design output is different from the tutorials
I have been studying Staad.pro Connect edition through youtube tutorials. However, when I opened the output viewer after running analysis for the concrete design, the results are totally different. I can't even understand the result of what I have done. here is my result    while the result from the tutorials is this    .   Now my question is, are there settings that I should change to have the similar format or I simple just made a mistake. if so, what are the possible mistakes. Thank you very much!
P.S.: I have Staad.pro Connect edition - Version 21.00.02.30
Parents Reply Children
