How to model, analyze, and design this reinforced concrete cantilever beam using Staad Pro?
You can model the beam in two segments and then offset the right segment using the member offset. Analysis and design would be like any other beam.
Answer Verified By: kadiem alqazzaz
Can you elaborate more about how to model it since I'm fairly new to staad pro?
Model attached for reference 1614.Structure1.STD
