Moving Load Generation - Vehicle Not Displaying
So I seem to be having an issue when using the moving load generator.  I have defined a custom vehicle with axle loads and spacings.  I then created the load generation case and then assigned the vehicle with the appropriate starting location and step increment.  The issue I am having is that for some reason, the start location of the vehicle does not display on the screen when I select the moving load for some reason, so i cannot verity its starting at the location I want it to.  In the past (prior to Connect) the vehicle and wheel locations would show up in red on the model and the reference wheel would be boxed. Is there a view setting or something else that I may have toggled off that would prevent me from seeing the vehicle start location?  Thank you!
Parents Reply Children
